I just had a hydraulic line replaced by a Mechanic. Everything is working fine now. However, the ABC Waring shows up in WHITE or GREY (hard to tell). Mechanic says he could not clear message. What does it mean and how do I get it cleared.
Thanks for the help!
· Outstanding Contributor
2005 SL600, (2) 2003 SL500
A Star Diagnosis System (SDS) or its equivalent is needed to read the diagnostic fault code from the controller which is associated with the warning. SDS can be had for as little as $200.
Current: '07 SL550, '06 ML350 - Past: '99 ML320 (Sold), '98 SLK230 (Wrecked), 05 SL500 (Wrecked)
Or the Foxwell NT510, which is less than $150 all-inclusive and is less complicated to operate by a novice and does 90% of most of the work that anyone would want to DIY.
Reading the ABC codes and resetting them is well within the capability of the Foxwell.
