1 - 13 of 13 Posts
I have a new noise inside. It sounds like air blowing from one of the vents, but it is not that simple. When I touch the brake peddle it stops.
W163 and General Mercedes Host
Threads galore on this - brake hiss
One example of many
===>>> Update your user CP info....
click on your icon----> click on Account Settings---->
goto Account Details----> add vehicle details---->
ADD your make model YEAR ----> click save
Super Moderator
Not hugely common, but it happens often enough that there is a kit (posted earlier in the thread), a member did a seal fix and found a seal for a Volvo was a direct fit. Other people just replace the booster with a reman or new one.
I've used the "red" Volvo seal on a BB I had pulled from a donor suv awhile back - planning to swap ours out.
I still have this ready to go should I need to. The initial "patch" repair I performed with the brake hiss was with spare bicycle tubing I had: cutting, wrapping, and zip tying it around the BB in the footwell, along the firewall. To this date, still works like a charm.
I also read about a UK member using saran wrap (plastic food wrap) and zip ties with good success.
Thank you for this information. I am going to try the bendy plastic wrap secured with zip tie temporary fix. I thought about food wrap, but wondered about securing it. I have also thought about PTFE tape as used to make joints in plumbing pipe joints. I think I will apply some PTFE tape then overlay it with a strip of bendy plastic all secured with zip ties.
Thank you for the reply. I went online and viewed a video about replacing the seal with the brake booster still in place. Looked awkward, but do-able. I am going to try the temporary fix of PTFE tape around the boot at the bulkhead, plastic strip overlay, and secured in place by zip ties.
If you use this method, be mindful that you look for the area/spot where the leak comes thru. I was able to find the location by pressing my finger on various points and test/hear for any hissing, with brake pedal depression and release. It's typically along the firewall perimeter of the BB circumference.
I like the idea suggested and performed by the other member - easy to apply and wrap tightly with several winds, then zip twice. Plus, the plastic wrap, I believe, would seal the leak better.
But whatever you use, if it works and holds, then that's all that counts. :)
GL. keep us posted.
2000 ML55 sold? 2013 ML500,? 2015 C250 estate wagon, 1927 Dodge 4 sedan, 1929 Dodge
Really by the time you do that and try and get it to work, a little more time you could have it repaired properly.
Super Moderator
@khomer2 Do you have that Volvo seal part number handy. I believe my 2000 ML320 is going to need a fix soon. I have more faith in the Volvo seal than the URO parts fix.
post#22
Discussion Starter #13
GL. keep us posted.
I will let you know you how it goes.😎
1 - 13 of 13 Posts
