98 E-320, 2003 E-500
I am looking at a 2003 E500 in pristine condition, but just a little higher mileage. Looks like it has SBC (brake problem) and Airmatic suspension fixed so the major problems are out of the way. :thumbsup:
The question I have is that this particular year (and model) says it has the 5-speed transmision, while thinking that w211 has 7-speed tiptronic. I am trying to find out whether it has the same 722.6 transmission that has 236.10 AT fluid as in our beloved W210. I can't find the reference.
I don't believe they has done an ATF service but if it's 722.6, then I will not be afraid to tackle the job or getting the car.
Please inform. Thanks,
'01-E320 & 02-ST2
It's the 5-speed.
The 7 speed wasn't until 06 IIRC, and I don't have time to go check. But the 2003 certainly had the 5-speed.
OT but I have to say it: be VERY careful if you DIY the brakes; failure to disable that Silly Braking Crapola has the potential for serious injury.
Good luck.
Banned
1999 E300 TD
I believe that if you check you will find that E500's 211.072 and 211.272 were equipped with 722.9 transmissions. What year was that-------
If you know the full six digit model number you can quickly determine the transmission type because some E500 had the 722.6 while others had the 722.9 as options
It's the 5-speed.
Good luck.
Thanks and same for the brake warning. It's true that reading about the SBC scares me a little - How they make something so simple too complicated and hence causing more trouble than its worth.
I, however, never like doing brake (too much work) - but the bigger question is that I wander if my regular mechanic can do it on the w211? Or will I have to bring it to the dealer?
Discussion Starter · #5 ·
I don't have the model number yet, but it's 2003, so most likely it is 722.6. I'll double check using its vin number, hopefully, it can be decoded.
Thanks,
JP
