1 - 8 of 8 Posts
2001 ML320
Can anyone tell me how to remove the front and rear door panel? I am planning on changing out the speakers.
Thanks!
Hmm..for the front there will be a screw behind the SRS emblem, one behind the trim behind the door handle. That trim just pops right off. Also under the armrest you will see a round tab that pops out and theres a screw behind there. Lastly there is a screw in the cover around the door latch. You will also need to unscrew the door lock knob.
2001 ML320
Battlecat,
Thanks for the information but it is for the ML. I have upgraded my speakers in my ML and now looking to upgrade my wife's E320.
Jares1 said:
Battlecat,
Wait what? do you need help with the ML or E320?
2001 ML320
Discussion Starter · #6 ·
Battlecat,
I am looking to change out the spreakers in an E320.
Raymond, do you happen to have the video for a W211? It is slightly different than the W210. The W211 doesn't have SRS emblem on the door nor does it have the round plug under the arm rest.
After some investigative work, I did see that a plastic flap is under the arm rest. I pulled it out and found a screw there. I would assume that there is still a screw behind the door handle plate. I also found a screw near the door latch on the side of the door. Hopefully that screw replaced the one behind the SRS cap on the older models.
Thanks all!
W210 Moderator
99 E320
j-
no, i only have the W210 from their info CD that i found on edsoto.com just before
he withdrew them. if i'm not mistaken, W211 may be available from MBUSA for
about $100
1 - 8 of 8 Posts
