2004 CLK 240 Coupe
There are fuses on the left (K40/2) & right side (K40/4) in the W208 engine compartment. Are you referring to driver's side, with fusebox F1 that has blocks A to C ? (fuses f1 to f27)
Is it the fuse assignments you need, or the external wiring from the fuses?
hi i know this is rather old but do you happen to have a copy of your allocation-fuses sheet? i need to figure out which fuses to use for backup lights and dash.
all i have gathered is for W210 but not for W208
any help would be appreciated
