2004 g500
Hey guys,
I have a 2004 G500 and was wondering if 2003 G55 wheels would fit on my truck.
My buddy who has a 2004 G55 had picked up the 2003 G55 wheels and tires and was hoping to use them on his truck but when he tried to put it on they wouldnt fit. I believe his caliper size was too big.
So just wanted to see if anyone had some info if these 2003 G55 wheels would fit my 2004 G500 since i believe mine should have slightly smaller calipers.
thanks!
figured i ll run this by you guys before i trying to install them on my truck as my friend lives quite far away from me
thanks
2002 G500
Did you ever get an answer on this?
03 G55
That particular rim, A4634011302 was used on 55's from 03 on up until MB started putting 19's, then 20's on them (difference being that in 06 or 07 they started adding a color code to darken up the spokes).
An 03 G55 rim has the same part number as an 04 (same calipers on both as well). The '05+ G55 have larger calipers, but, used the same rim.
I don't get the original ancient post -- an 03 G55 is identical to an 04 G55 when it comes to wheels/tires.
