ohlord said:Later w/ thread submission: Ohlord said one cause could be a skicky purge valve. The valve noticeable vibrates when it is working properly. Mine wasn't vibrating. Ohlord's cleaning the valve with MAF cleaner worked on my SL.Dianich said:Ohlord - - I bought a low miliage 2002 SL500 with the small leak code. I replaced the gas cap to no avail then I saw your remedy using MAF cleaner.
No frog heart beating in my purge valve and I cleaned it inside with the MAF cleaner, let it evaporate for 5 minutes and the frog heart came to life.
No check engine or code now and you can hear the partial vacuum when the gas cap is opened.
per your instructions - Thanks! Dianich
Dianich
