I need to change the fuel pump relay on my 2002 S500. Information I have found online says the relay can be found inside the car below the back seat on the passenger side. We removed the panel that covers the fuses and relays. While we can see the relays they sit too low and can't be changed. Is this the correct location, and if so how do gain full access to change the relay?
2003 S500
At the bottom of each front corner of the rear seat you will find a release handle - reach down and under, push down on the corner, push hard on the release, pull up on the seat. Repeat on the other corner. Lift the seat up and pull forward.
