2002 E320
I left the headlights on overnite and drained the battery. Managed to jump start car but now two issues;
1. Have to radio ID card but entered it on the radio but it comes back with the message "CODE"; after multiple tries it says "WAIT" and reverts back to "CODE"
2. None of the one-touch window buttons are working. If I press it half way down, it works but not one-touch mechanism
Does any one know how to properly enter the code as well as resetting the windows issue? Thanks much.
1999 E300 TD
You are going to have to pull the radio out and get the serial number off it and then call the dealer for the code.
As for the windows they will have to be re-initialized, which you can do on your own and I'm sure there is a sticky on it.
To save you some time - put the window down all the way and hold the switch in the down position for about 10 seconds then put it all the way up and hold the switch up for about 10 seconds. Do that for all the windows and the sunroof.
