w209 2002,
Hi peeps, would any know if the fuse box is the same for a 2002, as it is for the 2003/4, ?? the 2004 shows the tv fuse to be N03 brown -7.5 amp (in the boot). and also now the uk has gone digital would this old system still pick up anything ?? :confused: feeling very nervous about ripping fuses out ! hope to hear from some-one soon ,,,,martin
w209 2002,
Discussion Starter #2
tv problems clk 320 / 2002
Many thanks for your time and details for the fuse box - not tried it yet coz its raining 'cats and dogs' but will do very soon - hope its just the fuse !! ??
regards
martin:bowdown:
2004 CLK 240 Coupe
Hi
Before you waste too much time here, just check your VIN for CODE 860 TV tuner. From 07/02 to 04/04 this TV tuner (A2/42) is located next to the sound amplifier in the trunk behind the r/h side liner.
There is quite a detailed spec in the WIS, which suggest that is is compatible for PAL, NTSC, Secam, digital video processing, etc.
The fuse for the tuner is the same on all models.
w209 2002,
well done you, i ve been on ggooogle N wicki for ages trying to find stuff, not good with this stuff but i'll learn, i had a suspision id have to take some panels off but just did nt really wanna do it- but i;ll check the panels and see whats there !!
thank you very much, i dont know what wis is ?? but it sounds like some good stuff, - i;ll have a look on E-bay by the ounce i take it ??? (LOL)
chers
martin
WIS = Workstation Information System, which is Mercedes-Benz's official electronic shop manual. You can get a "bootleg" copy on eBay, or if you buy the Chinese SDS (Star Diagnosis System) clone/bootleg copy, it comes with that.
The rear SAM fuses are behind a panel in the trunk, but it's just a small panel that just fits in place with tabs. Open the trunk and look on the left side (well, I assume it's on the left on right-hand drive models?). The panel is about 12 inches tall and 4 inches wide.
