I just ordered some new Lorinser RS1 17x8 rims with a 26mm offset for my 2002 C240. (If you haven't seen them on a c240 check out their web site at www.lorinser.com) I've read that the recommended tire size on the from is 225/45 and the rear is the same with the option to go as wide as 245/40. Does anyone know if there will be a problem (i.e. rubbing) with me going with 235/45 on the front. I've been looking at the Yokohama AVS dB's and they're not offered in 225/45. I also planned on lowering it soon so will this present a problem.
