So when i turn on the a/c it blows air both at my feet and from the dash no matter where the nob is to direct the air. Also the air blowing form the dash and upper defrost is only cold and the air blowing at my feet is always hot no matter where I put the temp at. Any ideas?
Outstanding Contributor Always Remembered RI
Welcome to Benzworld. Please complete your profile as this will help members give you the most accurate answer to your questions. Location is also important when we need to help you find parts etc. This forum is for introductions only and all questions should be posted on the appropriate sub forum for your car.
To edit your profile simply click on quick links “edit profile” (quick links is top Right of the page)
At the bottom of the page you will find forum jump, click on this and view all the available sub forums and there you will find the technical forum for your car.
For FAQ see Benzworld help here:
Benzworld.org - Mercedes-Benz Discussion Forum - FAQ: General Forum Usage
Benzworld help is for general enquires and all technical questions should be posted on the specific forum for your car. If you are not sure which forum it should be on then please ask me and I will give you a link.
Regards
