2002 SLK 320
Hello all,
Try to figure out a logic tree on where to start on this code.
Air Injector fuse is okay.
My WIS disks are in storage so can't find a decent diagram
to locate relays etc to determine likely failure points
Any suggestions from the experienced one's?
Thanks in advance
Joe
1998 SLK 230
Just fixed this on mine. Took out the switchover valve and cleaned with carb cleaner, also actuated it with a hand vacuum pump. Replaced the check valve that is down stream of it, it was rusted up and letting air through both ways, blow on it to test.
Glove Personal protective equipment Human leg Carmine Fashion accessory
Automotive tire Motor vehicle Auto part Personal protective equipment Hood
Bag Luggage and bags Military camouflage Motor vehicle Personal protective equipment
Sleeve Glove Automotive tire Personal protective equipment Jewellery
