One day, w.o. warning the clutch pedal went all the way to the floor, sticking briefly.
After a few pumps clutch activation seems normal, though the problem recurrs at random.
Hydraulic fluid level in the brake master reservoir fine / no external leaks detected, but since @120K miles,
the brakes were flushed properly w all new Pentosin DOT4.
Still no leaks can be found, and so we suspect an internal seal failure in either one of the clutch cylinders ?
However, no instructions could be found on how to replace these, and/or bleed them.
Any helpful suggestions will be greatly appreciated.
