Vito 112CDI
Hi everyone new to benzworld and your help would be much appreicated :)
I recently bought a complete used electric window set for my vito including all switches motors and loom that runs lerft to right under the dash. The problem is there are 2 wires (red/green and black/yellow) that have no connections?? the earth(brown) fits to bulk head drivers side footwell. In another thread it was suggested they can be run without a relay so can be used without the ignition being on, this is not an improtant issue at the moment but would maybe be useful to sort out out at a later date. Just to get them to go up and down would be good right now!
Cheers Andy
· Outstanding Contributor - Always Remembered, RIP
Zotye Auto 1.5T T600 2016
Welcome to Benzworld Andy. Please complete your profile as this will help members give you the most accurate answer to your questions. Location is also important when we need to help you find parts etc. This forum is for introductions only and all questions should be posted on the appropriate sub forum for your car.
To edit your profile simply click on quick links “edit profile” (quick links is top Right of the page)
At the bottom of the page you will find forum jump, click on this and view all the available sub forums and there you will find the technical forum for your car.
For FAQ see the Benzworld help section here:
BenzWorld Help - Benzworld.org - Mercedes-Benz Discussion Forum
Benzworld help is for general enquires and all technical questions should be posted on the specific forum for your car. If you are not sure which forum it should be on then please ask me and I will give you a link.
Regards
