I just purchased my first Mercedes and it should be at my doorstep this Friday. I have purchased some 5 star 19" Hyper Black wheels and a paint kit to paint the calipers red. However, I would like to put some drilled / slotted LARGE rotors both front and back--I've found some that are drilled but they are not very large. Does anyone know where I can find these?
I would also like to replace the tail lights with clear ones but can't seem to find these either. Any help would be great.
2002 SLK 32 AMG, bone stock. 1987 190E 2.3-16 valve (destroyed). 2005 E320 new toy.
If you have the spare cash, check out Brembo...
More brake then you'll ever need, but they ain't cheap...[:D]
SLK32, ML430
RE: If you have the spare cash, check out Brembo...
You can't just bolt on larger rotors. You will need to either relocate your stock calipers or use new calipers. The Brembo kit will contain everything you need. Just be prepared to spend $$$.
