1 - 13 of 13 Posts
my problems started when my check engine light came on , the codes read p0175 p0700, so i changed my conductor plate and plug , then i took the car to the shop to erase the codes and get the car out of limp mode, my problem is the car does not shift well through 1st and 2nd gear, and the code p0175 pops up , did anyone have this problem before ? could i of ruined the car when it was in limp mode? can someone please help? thanks
was the connector leaking when you removed it? the oil could have traveled up the wiring harness and into the transmission control module. it is not uncommon for this to happen.
· Outstanding Contributor
YES and YES ,but like my other post to you check it out first don't just go changing parts unless needed.
Dean
1 - 13 of 13 Posts
