If you have a pdf of the A/C compressor diagram for a 2001 ML320 illustrating the low pressure charging port, it would be much appreciated. I need to do a recharge in a parking garage using portable lights, so finding structures/landmarks within the engine compartment is difficult. The engine is quite dirty, which also makes navigation more difficult.
Also, if you have firsthand knowledge of the precise location of the charging port and the direction it faces (up/down/right/left), that information would be helpful. I have found several links suggesting the location or posts with hyperlinks to paid resources.
Thanks in advance!
Current 2017 GLE350, 2007 S550, 2002 S430, 1998 ML320 Deceased 74 240D, 92 400E, 97 E420, 13 GLK350
Passenger side firewall, larger of the two aluminum lines. The schrader valve angles up and forward. In the photo is it just to the right of the gloved hand and is covered with a black screw cap.
