1 - 9 of 9 Posts
Hello,
I have a 2001 E320 that will not shift out of first gear. The check engine light is also on (I haven't gotten the codes yet). I can go from Park to reverse to neutral and drive. But I can not manually down shift or upshift. It has a very pronounced thud when I shift into drive or reverse.
The car has 165000 miles and has been well maintained. I have not spilled anything on the center console. I heard that this caused similar issues.
Any ideas or thoughts? Next steps?
Thanks!
:mad:
You need diangnostic codes to move forward. if you need to putter a bit in the meantime, you can check the tranny adapter plug and TCM for fluid leakage/contamination as prt of the process.
Current 2017 GLE350, 2007 S550, 2002 S430, 1998 ML320 Deceased 74 240D, 92 400E, 97 E420, 13 GLK350
^^+1^^
Another common fault for a Limp Home lockup is failure of the speed (turbine) sensors located in the conductor plate that sits on top of the valve body. A complicated DIY, but not impossible.
Here is link to great resource in the stickies: http://www.benzworld.org/forums/w210-e-class/1463460-mercedes-benz-722-6-transmission-faq.html
Can't do anything substantial until codes read and erased - however, checking communication erros on the adpater plug (replacement $12 part) and TCM check for fluid a good play until more is know. The PO715 speed sensor is common, but you really can't trust the code until you confirm the communication adapter/TCM are clear.
W210.265/2001, W220/S500/2000, Porsche 997 C2S/2006, GMC K1500/1992
Legend73
Did you DIY or dealer service ? How much it cost for the repair ? Feedback is required to use the benefit of this site for diagnosis. This is a community site for every member's saving or donation is highly appraised.
e 320 transmission problem
Hi there,
read your post ...sounds like I have a similar problem with mine ...
a whole cup of starbucks got spilled by my little girl and it affected the window switches soon after ...now the transmission is doing the same thing as you described it ...how did you solve the problem ....??????
Thank you very much for answering me ...
Carsten
Hi there,
Carsten
Carsten - sounds like you have a different problem than the OP. His was a speed sensor on the conductor plate located inside the transmission - yours appears to be due to shorting out the circuit board just beneath the shifter.
Here is a link describing the similar experience and repairs of others:
http://www.benzworld.org/forums/w208-clk-class/1353354-shift-module-removal.html
1 - 9 of 9 Posts
