Hey everybody,
Checked out those 2 tanks in my '01 CL500 and was wondering which is what?
The Upper one is nearly full of green liquid (presumably ABC hydraulic oil) and the bottom, smaller one got reddish, brownish colored fluid.
Also on the dipstick in the smaller one the fluid seems to be waay below minimum.
I suppose it isn't that bad though - the car doesen't report any errors, check lights, visit workshops.
Could you please tell me what the lower one is for?
I would be really grateful for your help. Cheers.
Automotive tire Synthetic rubber Rim Motor vehicle Personal protective equipment
Automotive fuel system Automotive tire Motor vehicle Automotive design Auto part
CURRENT: 2011 SL550 FORMER: C300, ML350, CLK550 Cabriolet, C240, ML320, 300TD
Upper is ABC, lower is power steering.
2001 CL500 2006 E350 4-matic
I believe both tanks should contain the ABC (green) oil..Perhaps someone wanted to save money and put regular oil in the power steering oil tank
Moderator
2000 S430, 2003 S430, 2000 S500, 2003 S600 TT, and 2005 E320 CDI
I'd flush it, just to be safe. It's really supposed to be CHF11S fluid in there.
That's actually one of the first things I tend to do, generally, with any new-to-me car in order to get a good, solid baseline--replace all fluids.
