Not to sound silly or anything. But when the doors are unlocked, you can push the trunk lock in to open the trunk. If it pushes in but the trunk is not opening, then something is wrong with the actuator
Hey guys...
Sorry it took a bit long to respond but i managed to get the trunk open.
I tried everything hat you all suggested and i gave up for a few days. Then last night i decided to try again cause i needed to used the boot/trunk. I tried the fob again and was not hearing the actuator at all so i decided ( again ) to use the key to see if it will trigger the actuator or any of the mechanical mechanism in the lock.
I pushed the slide key all the way up on the fob and inserted it into the key hole and carefully holding it ( so it won't break the fob casing ) and turned the lock clockwise and anti clock wise ( keep in mind that it was not allowing me to do this before ) till i started hearing a sort of clicking noise. So i thought to myself that at least i was hearing something now.
And after turning it a couple times i kept the key in the keyhole and pushed the keyhole button in and that was it...pop..the boot opened....much to my amazement and smiles...
I then pressed the FOB ans stared hearing the actuator sounding off...I pressed it a few times till i made sure i was hearing it over and over...I then proceded to check the fuse & the fuse box and all seemed ok...I then closed the trunk and pressed the FOB and pop...it opened.
This weekend i'm going to service the lock and check the actuator to make sure that it's good...if not...i'm going to have it replaced...
Thanks again for all your advice and support on this :thumbsup::thumbsup::thumbsup::thumbsup:
