2000 S500
Hey Im new here. I just bought a S500 has a few issues got it from a Auction and the battery was dead after jumping the battery i first notice the Cluster does not work. Is there any other issues i should look forward to having
10 Mercedes e350, 09 Mercedes GL450, 95 BMW 325IC, 89 Mercedes 260E, 84 Euro Mercedes 300D 4spd
What is the mileage?
How much you got it for?
2000 S500
138,000
and $2,400 that's because i was the first to check out the car after i checked it out the cluster went dead so no one else wanted the car because they couldn't read the miles
There is a extended warranty in USA for the instrument cluster
Call your lochal dealer to see if your car still under the warranty fir the instrument cluster,
W221 & Audio Moderator
2013 S550
There is more information. See post #4 at http://www.benzworld.org/forums/w220-s-class/1532684-2000-s430-instrument-cluster.html
As you will be able to see, there was both an extended warranty (10 years from initial date of service) on all cars, and a recall that applied to only some (by VIN). You are probably past the extended warranty date, but could possibly be under the recall. If neither, you're looking at as much to replace the cluster as you paid for the car.
To avoid that, check the last entry under "Instrument Cluster" in the W220 S-Class Encyclopedia at the top of this forum. There are ways to get it repaired at much lower cost than replacement.
2013 S550
First, welcome to the forum.
Take a trip through the W220 S-Class Encyclopedia sticky at the top of the W220 forum. You will find problem areas and many solutions discussed there. The best place to start in your particular case is the the buying advice at the bottom of the encyclopedia.
Don't let it scare you; you will likely not experience all of the problems, but without doubt you will see some of them. Hopefully, you'll have a feel for what to tackle yourself, and when to go to a dealer or good MB certified independent.
