1 - 9 of 9 Posts
Hello, I have a 2000 S500 that when I turn the key the car starts fine but then revs to approximately 4000RPM where it seems to pulsate (I have read that that is a safety feature to prevent over revving). I have replaced the MAF sensor on the advice of others but the engine still races. Do I need to reset something? If I attempt to drive the car, it just continues to accelerate until I turn the car off. (NOT A GOOD IDEA) Simply put, it's as if someone is flooring the accelerator. The check engine light was on, but no longer. I obviously can't drive the car to have it checked. Any Ideas?
Zotye Auto 1.5T T600 2016
It could be a faulty accelerator or throttle valve, better to have the fault codes read out first of all.
I hope maybe someone will look at this again. I bought an OBD II sensor today and hooked it up to the car. I got two codes P0110 and P0100. The MIL DTC code P0110 showed "Intake Air Temperature Sensor 1 Circuit." The Stored code P0100 showed "Mass or Volume Air Flow Circuit." Can either of these codes be the cause of the engine racing?
Disconnect the Air Mass Meter and start the engine, see if it stalls or revs. You may need to restart the engine a couple of times if it stalls.
The next thing to do is disconnect the accelerator and start the engine.
Than you Eric. I will. Is the Mass Air Meter the same as the MAF? I just replaced it. Of course it's possible I got a bad one. If it is the MAF, can I just pull the plug and stat it?
Yes it is the MAF and yes just pull the plug, it will set a fault code but you can clear this after with the OBD II test equipment.
Thank You again Eric. I pulled the plug on the MAF, and I couldn't even get it to start. I Plugged it back in and removed the gas pedal assembly. And it purrs like a kitten. It appeared the "Kick Down Switch" was sticking, so I worked that a little but when I plugged the assembly back in the engine roared back to the limiter. It looks like the gas pedal assembly is bad. Any suggestions on where to get one? I called my Local Dealer (50 miles away) and they quoted $185 plus tax. Ebay ranged from $75 (used) to well over $200. I don't think I'm interested in a used one. Any one have a good source? On-line or otherwise?
1 - 9 of 9 Posts
