2000 S500
Garage door came down on car and broke antena - Whos would I call to fix other than dealer in Florida
Glass Company ? Other?
I see i should be able to buy part for around $367.00
Im wooried about seal if I dod it myself
'02' S500 (W220)
You're selling yourself short. Why don't you try first before having someone else do it. When you get it detached you'll see how it is sealed. I bet it's nothing more then a rubber seal.
'02' S500 (W220)
In fact here you go...
1 Detach CTEL and GPS roof antenna from rear window with preheated spatula
CAUTION: Do not damage rear window
2 Remove roof antenna and remove adhesive pad from bottom of antenna
NOTE: Installation: Remove glue residues from antenna and glue new pad to bottom side of antenna. When gluing on antenna ensure that antenna is installed directly on the rear window after removing protective foil from adhesive pad. After installing a load of 20 kg should be applied to the antenna for approx. 5 seconds
3 Remove glue residues from rear window with cleaning agent
NOTE: Installation: Treat gluing surface on rear window with glass primer
4 Remove paneling in trunk
NOTE: right side paneling
5 Disconnect connectors (1)
6 Remove leads (2) to wire passage (4) together with rubber grommet (3)
NOTE:
Observe routing of leads in trunk
- Installation: Apply solution of soap and water to rubber grommet
7 Remove molding frame (5a, 5b) on rear window
NOTE: Molding frame on right and bottom
8 Remove leads from molding frame
NOTE: Installation: Insert leads into rubber molding channel with suitable tool
9 Install in opposite order.
