My car starts up but doesn't want to move out of place. Reverse does not work. Drive does not work. Shifting gears (left or right) does not work.
I'm being told this is a problem with transmission. Before I panic and look for a new vehicle, I'm hoping my car only needs the transmission fluid added or replaced.
So, my broker asked me, "Are you out of transmission fluid?". I answer, "I don't know". I looked for a transmission dipstick, but can't find one.
I've read online that there is no way to check if transmission fluid has run out.
2000 ML320 Mercedes Benz: Where is the transmission fluid dipstick
Assuming that I am out of transmission fluid, what is the next course of action? This article leads me to believe there is a temporary and immediate solution by adding transmission fluid myself:
http://www.benzworld.org/forums/w163-m-class/1461205-how-add-transmission-fluid.html
Any other suggestions about what I should do next?
