Hello, I am having the following issues with my door locks. Every time I press the lock button or remote control lock or Automatic lock (by car), the door lock does the following (lock/unlock/lock). Also, every time I go from stop and go the lock does the same thing (lock/unlock/lock) even though the door is locked. Do you what may be issue? It's not doing the hammer thing. Also, how do I disable to autolock?
Thanks.
02 ML320 06 ML500
99 out of a 100 times you will have to replace the door lock on the problem door, which you did not mention.
You disable the auto lock, by reading your owner's manual on page 33.
02 ML320 06 ML500
99 out of 100 times, you will have to replace the door lock mechanism on the problem door, which you did not mention.
You can disable the auto lock feature by reading page 33 in your owner's manual.
Thanks I was able to disable after following your instructions. It was on page 32..but thanks for your help!!
