2000 E55 AMG
2000 e55 can't charge a/c. NO fault code on a/c noly shows 2(which is low)for frion presure, try to put frion pump not don't start. Is there any trick for charging a/c or the pump is no good?
take it to a air con shop - they connect both sides low and high - then they evacuate to a vacuum first - if it doesn't hold they track down a major leak - if it holds vaccum , then they refill with the correct amount of new freon by weight.
Topping off a air con system from one side with a can of freon is cheap - but often will not do the job.
The aircon service with the machine/vaccum/etc this time of year should be under $80 at a good air con shop.
