2000 e320 wagon 2 wheel drive
Hello folks
2000 e320 wagon. My windshield washer fluid is not working. I replaced the reservoir tank and pump last year. Are there any fuses or relays ( or anything else obvious) I should check before buying a new pump again?
Thanks in advance
KG
Banned
1999 E300 TD
If you have a rain sensor I would look at under rear seat fuse 4. If you don't, look at under hood fuse 3----however, in either case check the washer relay under cover behind the under hood fuse blocks
