2000 E320 4-Matic Wagon
Our 2000 E320 wagon with the Command navigation system has recently developed an intermittent problem: car blows the #10 (7.5 amp) fuse in engine bay. This results in the car losing all steering wheel controls (radio +/-; trip computer; and horn become inoperable), console airbag light comes on, and the radio shuts down with message such as "insert key and turn on ignition or radio will turn off in 3 minutes."
Replacing the blown #10 fuse restores all the functions until it blows again (could be hours, could be days). Horn ring or instrument cluster were suspected. After 3-days in shop for diagnostics mechanic can not locate problem (he did not charge me). I am now wondering if it's possibly a radio/nav issue? (FYI - car had phone removed a while ago, and CD changer has long been inop.)
Anyone else seen this fault that resuts in #10 fuse blowing? Solutions? Suggestions?
'03 Z4, '02 E55, '11 ML350
Good afternoon Brayman,
FYI, you might try posting in the regular W210 column as this is the AMG column. You'll probably get a quicker response. Try the search function also.
Of course, that's after you complete your profile. :D
Good luck.
Mike K.
