2002 S600 V12, 1999 CL500, 2000 E320 4Matic Wagon, 1999 S420, 1997 S420
I've searched and not found this specific issue but have read hundreds of posts and dx many things already based on what I've found. So... 2000 E320 Wagon recently acquired with inop transmission and trouble finding a gear. Replaced conductor plate with good results, cleared fault code with my carsoft scanner, and proceeded to drive. First trip out was ok but needed to clear the hard TCM code to remove limp fault after that drove ok but only went a mile or so, then.... 2nd trip car went into neutral while driving just after I slowed down for a turning car. I used the brakes and all of a sudden went to get on the gas and nothing. Towed back home. Of course when I got it off the rollback it drove fine up the driveway. Tried restarting after that and it would start and run fine but would only go into gear once before throwing itself into neutral. I couldn't find any new codes and no check engine lights. So... ok I figured the gear selector module was bad because I couldn't run the data tests successfully with the carsoft and assumed it was faulty as is a common problem with this particular model. Got a used one guaranteed to work
and installed it and all seemed good to start. Same problem after installing new gearshift and selector. Properly re connected all fittings and the gear selector mechanism located under the shifter housing which includes that PIA snap on washer.
Checked every fuse on the car and found that the only one not working was#19 in fuse Box in Engine Compartment Driver Side near firewall. It also appears that this location #19 isn't used on this car as there are clearly no metal terminals to receive the fuse visible, like it's a 40AMP spare being stored there, that doesn't make any sense. Verified that the 40A fuse was good and couldn't get any power from the fuse terminals or the top of the fuse itself so I'm perplexed. Only info I received was can bus communication issue between the Gear Selector Module and the TCM but was able to clear that and proceed with diag. The specific code I got was a communication error on Module N15/5. If anyone can help with this I'd be thankful. Sorry for the long script. I'm also not sure if the ABS/ESP only gets power when needed like when the car is in motion but again couldn't see any metal that would connect that fuse to power and do see wires going into the bottom of that fuse location, and fairly heavy guage red wires.
