1 - 10 of 10 Posts
Could anyone who knows tell me if this would fit a w208 not lowered?
:surrender:
2-20x8.5 5x112 ET40 235/35/20
2-20x9.5 5x112 ET40 275/35/20
:surrender:
No it won't.
for the front you will need a 5mm spacer because the tires will rub on the suspension bolt.
and use 225/35/20 tires
and for the rear use a 5mm spacer because you will rub the inner fender liner. and use 255/30/20 tires.
go with an inexpensive tire like Nankang because they carry these sizes and you'll save money and the tire will last longer than the pricey ones
2007 Mercedes-Benz CLK63 AMG Coupe
No it won't.
Absolutely!
I have 8.5 inch wide wheels at the front with a 235/35/19 tyre and the inside of the tyre is about 2mm from the suspension bolt!!
:thumbsup:
Absolutely!
:thumbsup:
That's probably because your front wheels are 38mm offset. 40mm will hit the bolt and especially with a 235, get a 225 to ensure no issues later, and a 5mm spacer.
2002 clk430
go with an inexpensive tire like Nankang because they carry these sizes and you'll save money and the tire will last longer than the pricey ones[/B]
Do you recommend those tires I want to get those bigger tires for the rear and seen a full set of the nankang for front and back for a good price on ebay but didn't know there durability.
If you're not going to breaking the land speed record and you don't drive to hard then yes I would recommend them because they are cheap and last long.
No, they have a 35mm offset.
But good call on the spacer. I may pick some up to be safe.
:thumbsup:
2000 CLK 320
20”
1. Front 225/30 8.5 ET32-38 Rear 255/30 10 ET27-38
a. NS-II Ultra Sport by Nankang
b. G-Force T/A KDW by BF Goodrich
c. Pirelli P-Zero Nero
2. Front 225/35 8.5 ET38 Rear 255/35 10 ET32
b. NT-555 Extreme ZR by Nitto
3. Front 235/35 8.5 ET38 Rear 265/35 10 ET32
a. NT-555 Extreme ZR by Nitto
1 - 10 of 10 Posts
