1 - 15 of 15 Posts
Moderator
Mercedes
MRTIKKET probably got a boner reading this title... but I don't mind his input.
Anyways.. I was all set to purchase 17" AMG Aero monoblock I's for the 560, until I saw a nice set of 3-piece AMG wheels on a w126. It really is one of the best looking wheels I've seen on a w126... or any car for that matter.
However, after reading up and asking people oppinions on these wheels... I found that the 3-piece was prone to some serious cracks. There is a thread here on the forum showing pictures of how bad some of the cracks are. Apparently its so bad and common that OZ Racing(makers of the wheels) recieved a bulletin on the subject. However, some said that the cracks were due to overtightening of the bolts and has nothing to do with poor craftsmanship.
There's also the 2-piece wheels, which look the same, except I can't tell them apart. Apparently they are made by another company(BBS?) for AMG. These are more rare to find? However I have heard that these do not crack at all.
They seem to be very difficult to find for sale in the US. I have checked on classifieds on the net.. ebay, mercedes forums... and no one has them. There's a website that has a set of the 3-piece for $1500. I thought that was a bit pricey.
I also found out that there are 2 types... the 8.5" width and the 10" width. The 10" is just amazing to look at![8D]
My questions to the experts on this topic is... whats the difference between 2 and 3 piece, (besides the obvious) and what price range should I expect to find these? Just wondering since I don't want to be left looking for these wheels for so long at a price range that I can't afford. Which is more desirable... 2 or 3 piece? And any input on these wheels is much appreciated.... trying to learn more.[8D][}:)]
Snibble, don't get me wrong. I love the look of the 3-piece wheel. In fact, I didn't even know that the 2-piece existed. After being warned about the cracking issue with the OZ made 3 piece, I was wary because I've always had bad luck with tires and wheels. If it could happen, it surely would happen to me. After Satish put the 2 piece on his SEC, I was hooked on those. I purchased 2 of the last staggered setups MB had left in inventory. Over 4k per set of 4. They were OE equip. on the 600SL sport. The offset is 23 and 25, the fronts are 8.5" and the rears are 10" The rear lip on the 10" is so deep. Side by side, you can definately see a difference between the 3 and 2 piece. The 2 piece is 18" and 3 piece, I've only seen in 17" I also found a very nice used set of 2 piece for 2k, which I also purchased . They weren't perfect, so I had them restored, for a couple hundred bucks. I'm telling you the 18" 10" look absolutely incredible! Also just bought a set of 5 spoke original wide body only rims on ebay last week. Hope after refinishing, they look as good as french mercedes refurb.
One more thing. Wheelcollision.com has the 2 piece completely redone used for a reasonable amount. You have to look under the SL wheels on their site. They will be the most expensive under that heading.
Moderator
Mercedes
MRTIKKET - 5/11/2005 6:20 PM
Ok.. I didn't know that the 2-piece where 18". I thought that there were 2 and 3 piece wheels found in 17" only. Since I am looking for 17" rims.. I guess that my only option is to find a nice set of 17" 3-piece wheels. Thanks for the clarification
btw.. I see that you are capable of being a gentleman when you feel like it. If you keep up with your future posts in the same manner... it would be a much better forum.
W126C AMG 6.0
The "dish" look is deeper on the 17" 3-peice than the 18" 2-peice, believe it or not. True also, the 2-peice only available in 18" and vice versa, no 18" 3-peice. About the cracking, I've read everything you have and probably more on it. I have spoken to OZ about the issue and pursued replacement of one of my rear wheels when, after purchasing a used set, noticed one of the rears had a stress fracture around a lug hole. After going over all of this info and speaking to OZ and wheel shops that knew of this, they both mentioned air-gun tightening being the culprit. They should always be tightened by hand and the impact wrench jolts after reaching the bolt's max torquing point were causing the fractures. In my opinion, any wheel that cost $1500 ea. in 1991 should NEVER have an impact wrench problem, period. The alloy that the centers are made of is softer than most. Luckily, I found a NOS wheel to replace my rear with. I honestly don't think that a single stress fracture would cause any major problems but its scary to think about. If you decide to stick with the 17" 3-peice, make sure you get close up photos of the center bore and lug holes to check for cracks. I just had my set powder-coated and will try to put them on this weekend. They look pretty mean in black. About the 18's, I would love a set to powder-coat black but I'll have to wait on a deal for a set. Can't see spending the $4K when I'm happy with my current wheels.
Moderator
Mercedes
EuroCoupe - 5/11/2005 7:42 PM
Mike, thanks for the reply.. am I correct to say that the cracks occur between the lug nut holes to the center cap? Any other places where one should keep an eye out on? Also, feel free to pm/email me with info regarding OZ and the replacing a defective wheel. I thought that they wouldn't have any in stock to replace with. Can't wait to see pics of your ride either[8D]
W126C AMG 6.0
Yes, cracks go from inside edge of lug hole to center bore (cap). I will keep you updated if/when I hear anything about replacements but its a long shot...
The offsets on the 2-piece 18" SL AMG's is not 23 and 25 -it is 25 all round. Both the 8.5J fronts AND 10J rears are e25.
The 3-piece 17" AMG's are also 8.5J front and 10J rear but et 18 front and et 17 rear. (The 2-piece wheels were made by BBS).
The dish is approx 0.5 inch deeper on the 10J 3-piece AMG's than on the 2-piece. The outer rims were hand-polished on the 3-piece rims but machine polished on the 2-piece rims.
Whilst the 2-piece AMG's just about work on the w126, they were NEVER designed by AMG for the w126 - the 3-piece wheels WERE designed to fit the W126, as per AMG documentation. The 10J 2-piece rears have an offset of e25, whilst the 3-piece 10J rears have an offset of 17....so the 2-piece AMG's are 8mm closer to rubbing the 'inner' wall on the rear arches. They work, but it's VERY close. Ample room with the 3-piece wheels....and a deeper dish. Add to that the fact that the 3-piece wheels have 35 gleaming raised-head fasteners on each wheel (as opposed to the 20 flat head fasteners on the 2-piece), the 3-piece wheel ends up looking sensational. Those fasteners on the 3-piece look like jewels in a crown.
I agree that 17" is the way to go on a w126. Consider that AMG never offered an 18" option on the w126.
The Aero I's look simply stunning on the w126 sedan - simple but aggresive, as they have an offset of e11 and are 17". My 300SE wears the Aero I's.
There are PLENTY of 3-piece and 2-piece AMG wheels available on German ebay and ebay.uk - they sell for big money on ebay.de but on the ebay.uk site, they go for silly money.
Attached is a link to pics of the 3-piece wheels on my 560 and the 2-piece which were on my 500E (now wearing sensational 3-piece 18" Brabus Monoblock III wheels, which in my opinion simply outclass the AMG wheels...)
560 :
http://www.printroom.com/ViewAlbum.asp?userid=hakkinen&album_id=186013
500e
http://www.printroom.com/ViewAlbum.asp?userid=hakkinen&album_id=192395
http://www.printroom.com/ViewAlbum.asp?userid=hakkinen&album_id=191832
http://www.printroom.com/ViewAlbum.asp?userid=hakkinen&album_id=196839
300se
http://www.printroom.com/ViewAlbum.asp?userid=hakkinen&album_id=187990
Moderator
Mercedes
As usual.. thank you Talbir for your input.
I feel stupid now as I see that the 18" 2 piece and 17" 3 piece are obviously different in looks. The fact that one has "AMG" casted and the other "///AMG" is also another major difference. I thought they were the exact same wheels made by a different company. The 3-piece in my oppinion looks a lot better with the wider spokes. Its also meaner looking compared to the 18"... even though its a smaller size wheel.
I have my mind set on 17" 3 piece wheels... just need to find them someplace for a price I could afford. Be it in the US or Europe.. but the likelihood of finding them in my range would be in Europe.
Yes, very good point - the 3-piece wheels (and Aero I's) have the original 'AMG' logo.
The late '///AMG' logo only came into effect in late 1991 - once w126 production had effectively ceased. No w126 AMG would have ever had the '/// AMG' type homologation.
360TE AMG; 500E
So is there any way to replace or fix the center portion ?
Is anyone reproducing them ?
I have one wheel that has the cracks!
1990 SEC
Neil,
It is going to be very difficult to find someone willing to repair your rim.
I saw a set of 3-Piece AMG rims on sale on German ebay where one of the wheels had a crack in the center hole (hairline crack to one of the bolt holes). As I was thinking about purchasing a set of these rims I thought I'd check out what the consequences were if I were unlucky enough to get a cracked rim.
I called the Wheel Collision Center and their answer was categorical; Impossible to repair and dangerous to drive.
I posted the response on this forum and some members thought that if you could locate a very skilled aluminium welder (some suggested boat repair shops), you could possibly get it done. However, many were skeptical about this.
Axel....just read your updated signature and see your transmission is from a 500e !
Wicked ! The 500E 722.370 is different from the w140/r129 722.370 in that the valve body is different....and MUCH pricier than the 140/129 versions. Here in the UK, 140/129 722.370 valve bodies are approx 450gbp....the 500E 722.370 valve body is 750gbp !!!! OUCH !!
Way to go....I obviously enjoy the same tranny in my 500e too....
1990 SEC
Talbir,
Satish had both the engine and transmission in his SEC before he started his conversion to the V12 600 engine.
I'm in the process of getting her properly sorted.
Very excited about the whole project.[:D]
AMG 3-Piece rims project is well under way. Though with my luck, it will still take a while.
guys i would like to know if the the 3-piece amgs by oz racing fit a W202 C43 amg....too much intrested to know....cauz it comes with original amg of 7.5 front & 8.5 rear.....
1 - 15 of 15 Posts
