1 - 15 of 15 Posts
Hi there,
can anyone help with MB SLC 2.8 1975 electronic fuel injectors. I had on- six of bosch 0280150015 what i need to change now. Does anyone has them or at least something what would fit too? Somebody told me that i can install from more powerful engine too.... am not sure if its true.... all i could find out is that they dont fix petrol injectors.
Looking forward for your answer!:rolleyes:
R/C107 Moderator
I checked the ones that came out of my '73 450SL and they have the same number. Kind of surprised me because I thought they would be different.
R/C107 Moderator
can also somebody tell me the MB part number for these injectors?
I don't have that number but if you are looking at new you better be sitting down when you see the price.:eek:
R/C107 Moderator
thats why am looking for aftermarket or some other option
It would hep if you fill out your profile and let us know where you are.
There are sites that offer refurbished injectors as well as aftermarket. The refurbished injectors are tested, cleaned and checked in every way they can. In your searching look for the 450SL D-Jet because the 280SL was not offered in the US Market in your model year.
500SLC #2624. Black on Black.
Dombra,
The MB part number on these 000783523
You can use Bosch part number 0280150036 injectors, they are the same spec. (and in fact I think, but am not 100% sure that they supersceded the 0280150015 injectors).
As stated, German Star has these (000783423 though, but I believe interchangable). Here: Mercedes R107 Fuel System Parts
Also, if you are in the US, you can send yours to Witch Hunter Performance, who will flow, test, clean and refurb your injectors for USD$18 each. they are here: WitchHunter Performance - Injector Cleaning & Flow Testing Services
Good luck.
R/C107 Moderator
Foto, one of mine was the 036. I couldn't read it properly so I went with the other 4 I could read. Good to know. Thanks for the info.
Jim
Administratoris Emeritus
2021 SL770
Dombra,
Good luck.
If they are interchangeable, it's news to me. Of course, we have 3423 injectors, but not 3523.
1974 450SLC and 1973 350SLC
Dombra,
Good luck.
..i've sent two sets there already and posted here several times about these guys.. nice to see others doing same .If you want o see spec sheets let me know..or if you want to know specs just yell as i have the sheets....Jeff
well what he was referring to maybe is that the the 350 euro engine{which is why you dont have them} uses yellow and the 450 uses the blue injectors and some drivers "cars" can use either....he does like ridddles eh..Jeff
2021 SL770
Right, but this is for a Euro 6-banger. I'm pretty sure I could scrape up some Euro 3.5 nozzles.
Discussion Starter #14
Yes i have euro version of MB SLC 280 with M110 engine and injectors are greeninsh blueish. Could these guys from WitchHunter Performance - Injector Cleaning & Flow Testing Services could fix my injectors, the problem is that they dont spray petrol but you can literally see the petrol trickling from them?
R/C107 Moderator
Trickling is leaking and is not good. A short reply would be yes it will probably fix them if the inner coil- winding is good.
EPC shows it to be the 3423 injector. Are they clicking when voltage is applied? Have you tried soaking them in a sonic cleaner. (Steal your wife's jewelry cleaner, but don't get caught.).:thumbsup:
Doesn't the color refer to the pintel cover?:confused:
1 - 15 of 15 Posts
