2.5-16V Engine or Mosselman Turbo
2478 Views 4 Replies 4 Participants Last post by  stuey01
I have a 1986 190E 2.3-16V automatic and I have been thinking about 2 options:
(1) Swap the 2.3L for the 2.5L
(2) Install a Mosselman Turbo
Any thoughts on either of these?
Thanks...
W460 300GD
Thanks...
For what you get, the turbo is the better option IMHO as there is plenty of work for the swap or stroker. Unless of course, your 2.3 needs a rebuild, then the 2.5 first - turbo later?
SLK32, ML55, 2.3-16V
It turns out that the Mosselman Turbo brings the 2.3L up to 250HP while the 2.5L with the ...
It turns out that the Mosselman Turbo brings the 2.3L up to 250HP while the 2.5L with the same turbo only goes to 260HP...After a little bit of research, I think the collectability is retained by adding the turbo to the original engine...
Thanks!
2000 ML320, 190E 2.3-16V, 190E 2.6
hey corrado kidd
hey are you the same corrado kidd form the vortex? i used to have a corrado and be on there a good bit. but i sold it and am spending more time with my 16v. :)
