1983 300 SD; 2000 E320
After garaging my SD for the winter my front passenger window didn't work. It's NOT the switch. The motor made no noise when switched on either.
After struggling like a b__ch with the two torx screws that hold the motor on, I was able to pull the motor off. I had to pull and twist hard. When the motor was off it worked!!! I didn't test both directions though.
Then, I put the motor back on, and again it was tough to get it on. I hit the switch and voila the window went up completely!! But then it wouldn't go down. I pried the metal cover off the gear box but the round head/ bulb at the end of the motor drive shaft wants to stay in it's form fitting housing. The only way I can see getting the motor out now is to rotate it so it worms its way down. I can't get the geared teeth to rotate with a screwdriver the way Azimuth did (
Lastly, to get access to the torx screws I unbolted a few of the regulator bolts and flexed the regulator arm a bit. After the window was closed (moved only 1/2") the lowest bolt moved away from the hole. You can see it in the photo, the bottom of the "v" arm. Can I force this back by using a hammer or lever?
Thanks:bowdown:
1979 280CE
Is it the same regulator as a W123? I have a working W123 front passenger window regulator if its the same as your W126..
I believe it's a different regulator, though the motor may be the same
