1 - 8 of 8 Posts
2006 ML 320Cdi Off-Road package, 2010 E500 Cab
I've got a transmission problem, sometimes when I brake hard and then take of again without coming to a complete stop, (like at a speed-bump) it seems the transmission is in neutral and kicks into first the moment I hit the gas causing the car to jump and often spin the wheels.
Any ideas :confused:
Oops... its a '94 S500
400 SE
Is weird , i think these cars almost never use the first gear , not even from 0 speed , they start in gear 2 , somedoby correct if im wrong
well mine is 4 gears maybe is different.
No you're dead right they don't, and mine is the 4 speed too.
Thats what make it so wierd?
maybe you need to overhaull the box or check the pump:confused:
Yeah but maybe I'm lucky and I just need to replace the box?
Thanks for the advise. :surrender:
1 - 8 of 8 Posts
