1 - 8 of 8 Posts
'85 500SEL AMG, 91 560SEL, '99 E55, '00 SL600, '99 S600, '99 E300 TD, '92 190E
Hi,
I own a 1999 S600 with 60,000 miles. It is not a daily driver, I usually drive it once every two weeks. When I drove it Sunday, the power mirrors would not fold out and the driver side front window and passenger side back window would not roll down. Also, the steering column would not adjust. The suspension, ASR, SRS, and ABS lights are illuminated. I have checked all the fuses and disconnected the battery, but that didn't help. Any suggestions will be greatly appreicated.
Thanks,
Al
1995 MB S320V: 2006 kawasaki vulcan 900 lt
the first thing i would do is check the condition of the battery. i doubt that driving it once every two weeks will keep it charged.
1996 S600 (Sebastian), 1999 SLK230 Kompressor (Tie Fighter)
if it is the battery, then you might want to connect it to a trickle charger while you're not using it. this will keep the battery fresh and snappy. [8D]
Depends on the day!
Indeed, these cars are Very voltage sensative. Unfortunetly, the electronics on these cars make it hard to diagnose w/o plugging the bugger in.
Jonathan
Discussion Starter · #5 ·
Thanks guys, it was the battery. It was only holding 11 volts, enough to start the car, but not enough for the electrical system to work.
Thanks,
Al
94 s420 98 s420
Just curious why would the battery control the windows after the car is running? isnt that when the alternator come in? I tottaly disconnected my battery on a cadillac eldorado ( after starting )and everything functioned properly, all my accessories ran off the alternator. is it different for a benz? do some accessories run off the battery rather then the alternator after the engine started?
Discussion Starter · #8 ·
I don't know, I guess some relays don't click when the key is in "on" position and after it starts it just bypass it. Also, they are very sensitive to power, it must have a safety feature or something and goes into dormiant mode, that keeps it from damaging any electonics.
Regards,
Al
1 - 8 of 8 Posts
