1 - 13 of 13 Posts
1999 S320 SWB
I am in need of the wiring diagram for the central locking vacuum pump for the S320 1999. The last owner tried to fix the pump and did not reconnect the pump wires. Any help would be great.
Thank you
1982 MB 380SE 1999 S500
All the pump wires go to a connector that mounts to the pump. Are the wires out of the connector?
I have a layout of the wires to the pump on a 99 S500. Give me your pump part number and I will see if it matches mine. I don,t know if different year models have the same wire colors.
99 s320 member since 2009 fastest time 14.6 1/4 mile nitrous.
I tried using a diagram,and it burnt my pump out.I give up and will one day buy electric locks
Moderator
Thank you
Stephen,
I posted this information a few years back for all the pumps...
http://www.benzworld.org/forums/w140-s-class/1924785-someone-please-help-me-stupid-pump.html
Post 35
http://www.benzworld.org/forums/w140-s-class/1924785-someone-please-help-me-stupid-pump.html#post8002442
Martin
1999 S320 SWB
Pump wires
The guy I bought the car from tried to fix the door lock system and I don't trust they got everything back where it should go.
1999 S320 SWB
89 merceds 190 E 2.6 95 S320W
Here are the wiring diagrams of the connector. A37 on the pump
my front left door won't lock unless i close it first then reach over . i was told its a vacuum line. and after seeing the digram and seeing "front left door" how do i compare the diagram to under the hood?
ebay.uk had electric lock setup for our cars.i will order one for mine.But you still have to slam trunk,I'v done that 6 years now.
1 - 13 of 13 Posts
