Hello, I have a 1999 E320 4MATIC with a strange fluttering noise. Sounds like something flapping in the wind. It has just turned 179K miles. The wiper cowl screens were pretty well shot, removed them to be sure this was the issue, still making this sound. I replaced the radiator a couple weeks ago and some rubber where the intake air flows to and blocks airflow to direct to radiator was torn, duct taped it up and still making this sound. Had the underbelly pan removed from a previous job and did not have it on so there was the wheel well rubber pieces hanging out in the wind so I remounted this and it is still making this noise. Front drive shaft feels tight, banged on all the heat shields and they are solid. Drives and shifts normal but feel like something is going to let loose at around 60 mph.
It does not make any noise revving it in park or with foot on brake under a load. Also if I start from wide open throttle to 60 mph no noise until I let off the gas.
I made a short video:
Motor mounts were replaced about 4 years ago. Transmission mount was not replaced.
