1998 SLK 230 Kompressor
Hello I was wondering if anyone has or had the same problem I'm having. The CEL comes on and low fuel light starts flashing. I'm getting the code PO455 I changed the gas cap, the purge valve and gas shut off valve but, it's still happening every two days or so. Or right when the fuel gauge reads between 3/4 and 1/2 a tank. Can anyone help regarding this problem. There are no leaks I can see!! Thanks John
2000 slk230,firemist
i just had the exact same thing happen, read some old posts, tried tightening the cap then backing off a little, stopped so far, ohh turned the cap 180 degrees then tightened, pobably means nothing but it worked, at least till next time LOL!
