ML 320
Hello!
Believe it or not my 1998 ML 320 is still under 100,000 miles! Around 98,500mi actually. Anyways, I was wondering if anyone could tell what general maintenance, especially maintenance not listed on the generally service sheet, should be done at the 100,000 mark?
Thank You!
Super Moderator
The plugs and possibly the wires are overdue just based on time.
If the transmission has never been serviced then that should be on the list. Also both diffs and the transfer case.
Brake fluid is often overlooked so if you are not sure about that it need to be replaced.
Then the engine coolant is also ready for a change just based on time.
