1998 C280 Sport
The lights used to come on intermittently. I took it to my mechanic and he changed the brake light switch, but it did not fix it and now the lights are on continually. It comes on whether I have my foot on the brake when I start it or not. Also, my cruise control works fine with the lights on.
Could it be a faulty switch or is it my CU?
What is the next step to take in solving the light headache?
2000 C230 Sport
I have the same issue, has been on for years.
I was told at one point that it was due to a bad "lateral speed sensor" which was a few hundred dollars to replace.
I know that the traction control still works even though the light is on, which is the biggest concern.
2000 C230 Kompressor Special Edition
Lateral speed sensor is in your trunk on a tray right behind your rear seat. There is a plastic top with three plastic screws. A large screwdriver will help you twist them out. It is VERY easy to change yourself.
Mercedes A 1635420618 SRS G Force Sensor | Compare Prices
Good luck.
Make sure that is the correct part. It should be similar.
