I just picked up this 98 C230 and i'm having an issue i'm trying to figure out..
Seems to work fine,Wipes the window etc but it stops on the passenger side when not in use..About 8 inches up from the bottom or so..
Does not rest on drivers side
Does this happen when you use the intermittent setting b/c mine does the same thing...after some research I found a lot of things..check the fuse for one.
Combination relay maybe bad (ie the contacts maybe bad)
the linkinge under the cowl maybe jammed somewhere
