41 - 54 of 54 Posts
1994 S600 Coupe, 1995 S600 Coupe
Look ok. Be sure to see what they will charge for shipping. I've seen German sellers really jack up prices to ship to the US.
1999 S500; W140.051
That's a great deal if you can get it.
I used those same Sachs units on my '99 S500 sedan only I paid about $475 ea.
Replace the the accumulators at the same time; they're cheap.
1997 CL500
Discussion Starter #46
Once i replace the struts, do i need to bleed the system again, like when replacing the actuators, by raising and lowering the leveling valve underneath the car ?
1997 CL500
Discussion Starter #48
How does one know if when all the air is out of the system ? Is raising and lowering it from the valve once enough ?
W124 Moderator
Do the raise/lower drill a few times, maybe 3-4 and you are done. The system is supposed to self bleed, but I prefer the raise and lower approach.
Sent from my XT1710-02 using Tapatalk
1997 CL500
Discussion Starter #50
And at the same time to check the reservoir in the engine compartment to make sure it's filled properly while engine is running, and just add fluid.
W124 Moderator
Yes. Only use MB hydraulic fluid....
99" CL500 , 99' CL500, 97' S500, 01' S500, 02’ G500, 09’ G550
Sorry to bring this back... anyone have the link to the ‘turned down bmw control arm bushings’ for the lower strut bushing... searched for 40 minutes already
600 coupe, one of the very first built
You're most welcome :)
Thank you very much.
I did the Bilstein rubber bushing replacement and I’m not happy at all.
Edit: only to find out that I commented on the tread in 2016 🤦‍♂️
41 - 54 of 54 Posts
