The posts I found on testing the starter all seem to deal with the later w210s using the K40 relay but perhaps I am missing something. I am thinking my model doesn't have the K40 or I haven't found it. I have a strange situation or at least the progression seems strange to me. On Friday afternoon, I went to start my car and there was like a jolt (cranking) but it didn't start. Then when I tried to start, two or three times I only got a buzzing noise behind the dash but no cranking at all. Then the next try it fired right up. When I got to where I was going and had to restart the car again, I had maybe four or five attempts with the buzzing sound but no crank and then the next it started right up and I got home. The next morning the car fired right up on the first attempt. Then coming home it required another three or four tries with no crank and then fired up on the next attempt. I made it home but then later in the day and since when I turn the key I only hear that mild buzzing sound (which seems to come from the area behind the driver side fuse box where there are some cables plugged in) but the car does not crank at all.
I replaced the battery today because it was due for that anyway and it made no difference. Since the car drove just fine the times it did start, I'm assuming it is not the fuel pump. I want to check the starter or maybe the starter relay but I'm not sure where it is located or how to check. I'm hoping it's the relay and not the starter itself after reading that it is a pain to replace the starter. I already checked all the fuses under the hood that I could find and the ones under the back seat just in case.
