I have all the three keys: Key Fob, Valet Key, and Flat(Master) key.
I can open all the doors, the trunk, the glove. The dome interior lights come on. The headlights are fine. Radio comes on.
However, when I insert any key into Ignition to turn to Position 1 or 2, it just does NOT budge from Position 0. I tried using the Flat(Master) key, push back n forth like many times but still no luck. I sprayed lubricant into the keyhole and tried several times. Nothing.
The switch blade key in the Key Fob and the valet key shows a little bit of wear but the Flat (Master) key looks fine.
Please provide any tips to resolve this key issue without having to tow the car to the local MB stealership. Other than that, the car runs pretty smoothly, was running smoothly until this happened. Thanks.
