1 - 11 of 11 Posts
I have a 1996 sl 320 with about 60,000 miles. During the past 2 weeks twice after the car was turned off it would not start again until about 15 minutes later. Battery is nearly new and the engine spins over fine but it won't fire. I checked all fuses for ignition and injection and they are ok. Plenty of gas in the tank. I'm thinking crank position sensor but once running I noticed a dash light at idle indicating a brake malfunction which goes out once the car is underway. Any suggestions would be most appreciated. Thanks... Bill
1997 SL320 Sport
same issue...
97 sl320..just bought it..now wont start...just cranks and cranks...charged the battery still the same. Im thinking more along the lines with you..crankshaft Pos. sensor...does anybody know how to test it?
thanks
Michael
1997 SL320 Sport
fixed...
You are correct #22 is the Crank Sensor, problem was the key. When I swapped the remote Key housing I may have damaged something, anyway...with the new $30 (remoteless) key it started right up. But the shortly after the first key started working again....so...maybe its the module behind the key?
91 500 sl Japanese Import
Starting problem
If it does eventually start. Try the fuel accumulator. It was the problem with my 91 500, it acts like a back flow valve. If it isn't functioning properly the fuel pressure will be released, hence hard to start.
1991 500SL V8 NEOKEN modified T/B. 2000 F350 4x4 V10. 1995 SL500
My car eventually started after about 20 trys. Still ended up being the contacts in the module for the switch. I took it apart and adjusted the contacts and WOALA.
2000 Obsidian Black Metallic Mercedes SL 320 V6 (SOLD) 2012 E 350CDI Cabrio 265 PS
Guys I'm sorry to be pedantic but please update your profile with your car, year and location to help us help you in the best and quickest possible way. For us it’s extremely important you do this.
Cheers
1 - 11 of 11 Posts
