***Update!!!!!!!!***** In one last attempt today I disconnected the battery for a few hours, unplugged the aftermarket GPS module from the OBDII connector and rechecked all fuses.... I found one fuse that I overlooked in the fuse panel in the trunk that was missing and another was in the vacant spot and not in the right slot (#1 was missing & I think #3 was plugged into the vacant #4 slot.) Anyway after I reconnected the battery she fired right up!!!!
Sorry Mr. Mechanic, no $4800.00 for you this week... AC blower still isn't working, and the buzzing in the dome light is still present, need to research these now but progress is being made!
I think the GPS device caused some electrical issues and the previous owner pulled fuses to make things stop buzzing, battery draining, etc. or whatever, and then the fuses not being present in the right slots caused the no start. **********
Hello All,
New to the forum and seeking advice and guidance on a non-start issue.
Brief summary:
- I am now a new owner of a non starting 1996 S500 4 door, automatic trans (was starting and running great 2 weeks ago), now it only briefly starts for half a second then dies like the fuel and /or spark is cut off. Does not get to idle, it barely ignites. Can get a quick "half rev" in if pedal movement is timed perfect (will not help I know, but just to give you an idea there is fuel and spark for a very brief time period)
- A GPS tracking device (Audiovox Car Connection) was installed into the OBDII connector by previous owner
- Car started and ran fine after it was installed. GPS device never worked properly I am told.
- Electrical Gremlins hitched a ride soon after:
-AC blower wouldn’t shut off even after key was removed, Fuse was removed to stop the blower from draining battery.
-Buzzing noise by the interior dome lights (but would stop after timed shutdown of all electrical components).
- all this and monkeying with fuses and then the car wouldn't start anymore, Car was jumped off prior to all of this several times and also tried jumping after these events (reversed jump or over voltage by jumping is not out of the question, but all fuses have been checked in front and rear panels and in main ECU, all appear ok and all fuse are back in)
- Car was taken to local shop and diagnosed as needing a PCM Module, and basic Module + programming with a quote of $4800.00 (does this sound right???), previous owner gave up and was going to junk it. Now its my project!
I took the battery out and fully charged it for 6 hours, this would have rest the ECU and it had full voltage, still no start. Looking for advice on what to do next, I have not pulled the codes personally as I do not have a Scanner.
Should I buy a scanner first and pull the codes myself?
Are the ECU’s plug and play where I can just buy a used one and swap it out?
The battery has been connected and disconnected several times, could this be a security/immobilizer issue or something with the Key?
Looking for advice and guidance on the best (and cheapest) way to proceed. Was hoping it would be something small and easy to fix but with all the electronics on this car it might get real pricey real fast….
Hello All,
Brief summary:
