Hello All!
I have a 1996 C280 with no working brake lights. Been troubleshooting the issue all afternoon and have reached a point of not knowing what to try next.
Conditions:
1. No working brake lights.
2. Fuse #30 (20 amp) blows instantly when ignition switch is turned on.
Troubleshooting so far:
1. Removed both brake light bulbs. Replaced fuse. Turn ignition switch on. Result: Instantly blows fuse.
2. Removed wiring connectors from both sides of trunk lampholder assemblies. Replaced fuse.Turn ignition switch on. Result: Instantly blows fuse.
3. Removed brake light switch from above pedal. Replaced fuse. Turn ignition switch on. Result: Instantly blows fuse.
2623528
2623529
2623530
I've included a few photos above. Any ideas on what I should try next?
Thank you everyone in advance.
Discussion Starter #2
Update: I decided to run a hot wire to the brake switch and was able to solve my problem.
Hello All!
Conditions:
Hello All!
Conditions:
You need to trace the cable.
