hey all,
First when it happened. Heading home from work at about 45mph, then the car just shut down with no heads up. Just off. I didnt even know until i was trying to give it gas and it didnt move. Pulled over and tried to start it and nothing. With key in position number 2, all the lights come on like normal then i look up and see the red/green flashing together. From what ive read its related to the security system but how and why i dont know. The car will crank and crank and crank all day with nothing, not even a suptter. Also the key will work all the locks like normally.
Ive had this happen on my subaru before, i just reset the ecu and it was fine again.
Someone has had to have this happpen, how did you find your fix? A lot of threads are dead end streets :-/
is there a reset for this?
What i have tried:
Many lock and unlock cycles with both of my keys with no sucess.
I have a Voltage relay comming to see if thats it.
Discussion Starter #2
relay just got here, car fired right up.
part# 0005406745 overload relay
Hopefully this will help others
-Roman
